Go to Post Sometimes the team really needs the kid, and sometimes the kid really needs the team. - Taylor [more]
  #37   Spotlight this post!
Unread 05-04-2009, 12:56
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: pic: T-Shirt Launcher, still needs a chasis
Originally Posted by Mr. Freeman View Post
Seems to me that if PVC rated at 400+ PSI fails at anything less than 400 PSI then it was either:
A) Not actually rated
B) Not properly used (exposed to conditions it wasn't rated for, etc.)
Apparently you did not read my previous post.
PVC is not rated for compressed gasses. It is only rated for liquids. The difference is not in the pressure itself (as 400 PSI is 400 PSI). The difference is in the failure effect. With liquid the PVC will split and release it's pressure quickly (as liquid is only compressed as far as the gas within the liquid allows) while the gas will rapidly expand and sunder the PVC causing it to expel the shards in all directions.
Whats worse is that PVC gives no (or very little) warning that it is about to fail and that the PVC item in question may have been operating "properly" for years (as was the case with the 1 liter volume I discribed earlier).
Oh, and another thing ... The forces on the barrel and breach are almost instantanious (sp?), whereas the t-shirt takes time to be expelled from the barrel ... thus the entire force of the air is applied to every surface (universal gas laws) within the cannon. So when you fire the cannon it puts almost 60 PSI (assuming thats the pressure you are using) on every portion of that cannon being used until the t-shirt leaves the barrel. Not only that but those forces are applied as a shock load which is about as bad as you can apply to PVC due to its brittleness properties.
as to another question in this thread:
And as far as making PVC safe for use with compressed air ... the only way you can do this is to ensure that the blast from a catastrophic failure (when it happends) is contained.
And lastly ... if someone doesn't want to listen and makes a pneumatic device out of PVC, well I personally don't care too much. If they want to hurt themselves thats fine. But when they state that they are going to use it for 'marketing' then I have to stand up and be heard, because those near the device may not fully understand the dangers that the device presents.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
