Go to Post Yeah refs are trained to not have a sense of humor about things like that. - Koko Ed [more]
  #40   Spotlight this post!
Unread 05-04-2009, 19:51
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: pic: T-Shirt Launcher, still needs a chasis
the reason it fails is that PVC was never rated to go from 0-60 psi and back to 0 in less than a second.
the instantaneous stresses are just too much.
think of it this way, your tires give you traction at 60MPH, but if you try to go from 0-60 too fast, you'll spin out...
i know, it's totally different forces at work, but the result is essentially the same.
it's MUCH harder to create instantaneous pressure with liquids, as they do not compress, and once given more volume, return to 0 without much trouble.
i've seen first-hand the problems with PVC AND ABS!!! IMHO, don't use plastics of any kind for air pressure, unless they are flexible (ie. Pneumatics tubing)
just use metal.
Just my $0.02...
-Z
[center]
pic: Team 935 Chasis railerobotics Extra Discussion 24 27-01-2009 22:26
T-shirt launcher FRC 1985 catsylve Robot Showcase 4 21-09-2008 19:14
FVC World Championship still needs volunteers! vavex Championship Event 0 18-03-2007 18:09
pic: Current Robot Chasis Pnakovich Robot Showcase 13 13-02-2007 17:55
