Go to Post The best parts of FIRST just cannot be described. They have to be experienced. - sanddrag [more]
Unread 04-09-2009, 11:10 PM
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
pic: 1557 upgrade for atlanta
Unread 04-09-2009, 11:12 PM
gorrilla's Avatar
AKA: adam spears
Re: pic: 1557 upgrade for atlanta
this is the new motor we are putting on our STOD for Atlanta
replaces a Keyang(5 times faster and more torque)
Its lighter too
I was wondering how other teams made adapters for FP gearbox?
Adam Spears
2010: Goveners Award.
2010: UL Saftey award.
Unread 04-09-2009, 11:13 PM
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Im guessing STOD stands for Stem of Death, and if im right i also guess that that is your "bristle pole" for your helix? lol
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 04-09-2009, 11:16 PM
gorrilla's Avatar
AKA: adam spears
STOD means
Spinning
Tube
Of
Death
yes its our "bristle pole"
its pushes the balls against the lexan and they ride up our spiral
Adam Spears
Unread 04-09-2009, 11:25 PM
MrForbes MrForbes is offline
We used an AM Stackerbox for that function, with a CIM, and chain reduction drive from it.
We used an FP motor for our intake roller, with a custom made "housing" (two plates of 1/8" aluminum and a plywood spacer between them) with only the first stage of gear reduction from the FP gearbox, again using chain reduction to drive the roller.
Moving all 15 balls out of our spiral hopper in 3 seconds takes some fast turning!
Unread 04-09-2009, 11:32 PM
dodar's Avatar
We just chain drove ours with a CIM on the Toughbox and awww dang, I was so close to the abbreviation lol
Unread 04-09-2009, 11:38 PM
gorrilla's Avatar
AKA: adam spears
We thought the Keyang was going to be fast enough(was not)
And we are already using all of our CIMs........
The STOD is PVC and has a 4" cleanout on the bottom which has a 1" square hole in it,
so all we have to do it "slip" the square tube an FP under the STOD and put the tube in the cleanout and its good to go
thinking back....
we should have used the FP on our intake roller instead of a CIM, then we'd have it for the STOD, but o-well(just one of our design "quirks")
we're gonna do so much better with the faster intake rate..........
Adam Spears
Unread 04-10-2009, 11:13 AM
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
Oh I love seeing improvments of robots or robot devices between competitions.
Unread 04-10-2009, 01:23 PM
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
On 228 we've made adapters for the full FP gearbox. Aluminum hex plug drilled and broached for keyed shaft with a hose clamp to hold the plug into the FP bearbox output.
This year we pulled the first two stages out of the gearbox and one of our alumni / college mentors fabricated custom gearboxes for them.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 04-10-2009, 01:40 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by skimoose View Post
On 228 we've made adapters for the full FP gearbox. Aluminum hex plug drilled and broached for keyed shaft with a hose clamp to hold the plug into the FP bearbox output...
By any wild chance, do you happen to know the dimensions of the hex stock you used for the plug?
Unread 04-10-2009, 04:02 PM
EricH EricH is online now
Wouldn't it be the dimensions of the hex on the inside of the FP output?
BTW, I can vouch for the hex type of connection; 330 has used it several times (2005, 2007, 2008). The hose clamp is in case of somebody driving the motor when what the gearbox is attached to can't move... It'll keep the gear pieces together enough for limited functionality until you can replace the gear.
Unread 04-10-2009, 04:57 PM
billbo911's Avatar
Wouldn't it be the dimensions of the hex on the inside of the FP output?...
Yes it would be.
The reason I asked is that I am at work and will not have access to any of the KOP items for more than a week. In that time period, I can have the stock ordered and in my hands by the time I get back to the school. I just need to know the size I need to order or pick up at the materials supplier.
Unread 04-10-2009, 05:43 PM
You're one step ahead of me; I won't have access for about a month...
I remember it being about 1.5"-2" across, but don't quote me on that. It's been a while.
Unread 04-10-2009, 07:07 PM
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
I made a modification to the FP transmissions. I removed the first gear and moved the motor so that in effect makes for a 3x speed and 1/3 torque. I THINK. If my numbers were right.
I documented what I did on You tube if anyone is interested. It's a boring three part video so if you just want the numbers it's on the third part .
http://www.youtube.com/watch?v=rbIe68UzETk
Performance turned out to be great!
I also milled octagonal aluminum inserts with the hose clamps and a slotted 1/2 inch axle so I could use 1/8 inch key stock to make everything work together.
Steve
Unread 04-10-2009, 08:52 PM
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Just measured ours. It's 1.5" Hex.
pic: 1557 with Chairmans Award gorrilla Extra Discussion 14 03-29-2009 11:01 AM
pic: 1557 at robot ruckus gorrilla Extra Discussion 14 02-16-2009 08:05 PM
pic: 1557 3rd week progress gorrilla Extra Discussion 12 01-29-2009 11:14 PM
Time for an Upgrade stuffssguy General Forum 4 02-15-2008 02:00 PM
Planned downtime for upgrade. Brandon Martus Announcements 14 03-30-2005 10:12 AM
