Go to Post Can't engineers be jesters? - danielkitchener [more]
Unread 10-04-2009, 21:38
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: pic: Team 2022's Drivebase
Originally Posted by JHSmentor View Post
So - did you drive this as a crab drive or did you switch between all wheels pointing in the same direction (crab) and having the front / back wheels pointed in opposite directions? Or - did you just drive with the front and back wheels turning oppositely?
I ask because our bot this year was a somewhat similar design but probably a lot more simple (we just don't have the equipment to do anything more fancy). We had Ackermann steering for the front wheels and Ackermann for the back wheels separetely so they would turn opposite each other. our experience was very similar: we could push any other bot around easily and in many cases, 2 bots at a time (no traction control used either). Having properly designed Ackermann steering allowed the wheels to point in the direction of the turn at all times so there was no slip required to turn.
We had crab drive for most of the time, however, whenever the trigger on our steering joystick was pulled, and the stick twisted, the wheels pointed opposite directions for turning.
The reason we were able to maintain traction, was because we had less power than other robots. This made it so that we never broke into dynamic friction.
pic: EngiNERDs - Team 2337 - Team Work After Ball Popped Clinton Bolinger Extra Discussion 3 23-02-2008 23:10
pic: Dawgma 1712 NEW and IMPROVED Drivebase Chuck Glick Extra Discussion 4 13-01-2008 15:30
pic: Team RoboRaiders(75) and Team Mu Mu Psi(2016) versions 2007 Rohith Surampudi Robot Showcase 5 22-02-2007 08:43
Team 1425 Drivebase and Wiring Sparks333 Robot Showcase 5 05-02-2007 10:41
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
