Go to Post The GDC is the Grinch because they just stole my Christmas! - scottmacdonald [more]
Unread 21-04-2009, 10:00
MrForbes MrForbes is online now
Re: pic: Sliding Wheel Chain Tensioners
That's a neat idea!
I do see one potential problem with it...since it's a square tube, and there is nothing surrounding the bolt, the tube will crush before you get the bolts tight enough to securely clamp the tube in place so it won't be slid by chain tension under load.
Adding a 3/4" long spacer around each bolt might help.
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
