Go to Post Coming between me and my Hawaiian shirts would be like trying to get between Dean and denim. - dlavery [more]
Unread 21-04-2009, 10:26
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Re: pic: Sliding Wheel Chain Tensioners
Originally Posted by squirrel View Post
That's a neat idea!
I do see one potential problem with it...since it's a square tube, and there is nothing surrounding the bolt, the tube will crush before you get the bolts tight enough to securely clamp the tube in place so it won't be slid by chain tension under load.
we solved that problem by adding a piece of PVC pipe as our space for a similar application. It worked quite well.
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
