Go to Post Teamwork, dedication and friendship have a lot of play in all factors of life, including a robot contest. - tenthirtythree [more]
Unread 21-04-2009, 12:00
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: Sliding Wheel Chain Tensioners
That might work a bit better if you had two shorter slots, one for each of the bolts, and you limited the play as much as possible. Use it to take up the slack in a chain or belt, but don't use it to reposition the wheel significantly. (So you'd only need, at most, one chain or belt pitch worth of play.)
Also, I assume this is intended principally for a dead axle system. If not, you're going to have a hard time rotating the shaft, if there's any misalignment.
And while you're at it, you probably want to use some flat washers under the bolt heads and nuts, so that the tightening process doesn't embed the hexagonal surfaces into the chassis rails. This assumes that you're going to use nylon locknuts and will design the system so that you can apply significant bolt tension without crushing the channel.
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
