Go to Post Success is making a difference. - SlamminSammy [more]
Unread 21-04-2009, 19:39
MrForbes MrForbes is offline
Re: paper: Cyber Blue 234 Belt vs Chain Technical Evaluation
We made a change between Arizona and Atlanta that made us go about 30% faster....we bought some sprockets from Small Parts Inc for under $10 each, and brought a short piece of #35 chain and a couple extra master links with us. I hate to think of what it would have taken to make this change if we had used a toothed belt drive.
If the robot is right at the edge of optimum performance (not the case this year), then the efficiency is important. Most years it does make some difference, but careful drive ratio selection might be more important. The wide availability of different tooth count #35 sprockets, and the ease of changing the chain length, seem to me to be a much bigger advantage, especially for teams like ours that don't have enough experience to get it right the first time.
My point is that there seem to be a lot of considerations that you left out, which may not be important to your team, but make a big difference to many other teams.
Still, it's great that you did the research, and showed us that there is advantage to be gained by careful experimentation. It would be neat to see more belts on robots next year. The experiments with smaller chain and belts will also be very helpful, and if more teams see the benefits, they will increase demand for the parts, and hopefully it will become even easier to make these changes.
paper: Cyber Blue 234 2009 Chairmans Essay Chris Fultz Extra Discussion 0 21-04-2009 09:04
paper: Belt vs. Chain Drive Evaluation - Team 234 Chris Fultz Extra Discussion 10 25-02-2009 14:09
paper: Cyber Blue 234 Business Plan 2008 Chris Fultz Extra Discussion 3 21-04-2008 12:53
paper: Cyber Blue 234 Chairman's Submission 2008 Chris Fultz Extra Discussion 1 20-04-2008 21:09
White Paper Discuss: Cyber Blue 234 Design Review Process 2004 CD47-Bot Extra Discussion 1 18-03-2004 22:51
