Go to Post There is a big difference between "we have not been able to figure out how to do it." and "it's impossible" or "don't even bother." Let's be constructive not discouraging. - PVCMike [more]
Unread 21-04-2009, 22:49
MrForbes MrForbes is online now
Re: pic: Sliding Wheel Chain Tensioners
When you try out this idea, I suggest you look up the torque specification for the size of bolt you plan to use. Get a torque wrench, and see what happens to the tube and channel when you tighten the bolt to spec torque with a spacer, then remove the spacer and try again and see what happens. I'd be interested in the results.
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
