Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 22-04-2009, 00:45
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
Re: pic: Sliding Wheel Chain Tensioners
Yea the chasis will flex when you tighten the bolt.. thats what happend to our robot this year. To fix it all we did was just cut aluminum blocks, drill a hole for the bolt to fit in, slide it into the channel of the chasis, and then tighten.
Neat Idea.
Andy Mark Sells something that tightens chains though.
http://www.andymark.biz/am-0286.html
"There's always next year..."
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
