Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
Unread 02-05-2009, 21:57
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
pic: Project PHoundation
Unread 02-05-2009, 21:58
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
Re: pic: Project PHoundation
What thickness of Aluminium are you using?
Nice Render by the way
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
Unread 02-05-2009, 22:08
Spark The Ancient
.125 walled extrusion, for both the rails and crossbeams
Unread 02-05-2009, 22:21
Joining the 900 Meme Team
FRC #0079
AAAAND The offseason has officially begun.
Looks very nice.
Unread 02-05-2009, 22:30
MrForbes MrForbes is offline
this is a subliminal hint to the GDC to do away with the "full support behind the bumpers" rule?
Nice design. Seems it would be useful to have the team come up with several different chassis/drive ideas, that will work with different possible games (long/narrow, short/wide, ramps, funny surfaces, with/without bumpers, w/without floor harvesting, arms, etc). I know the 6wd long robot stuff we worked on last fall was way different than what we ended up building!
Unread 03-05-2009, 01:36
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Nope. I think it's pretty blatant. Besides. Couldn't you hear the screaming all year? *hehe*
This is a beautiful render. Thanks for sharing this!
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 03-05-2009, 07:05
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
And 6 inches on both sides of every corner rule?
Looks nice. Hopefully it could be used in some future competition.
(since 2004)
Unread 03-05-2009, 10:36
You might consider extending the beam that the wheel is mounted to out a little bit so that if you ram a wall at high speeds, you don't break/bend the wheel. 254 welds a piece of 1x2 out front for this purpose. And has broken it off before in a match.
Looks pretty good otherwise.
Unread 03-05-2009, 11:36
Spark The Ancient
the wheels are extended beyond the frame to allow the chassis to overcome steps and other small platforms. this is also why there are no bumpers on the corners. This could be amended to fit the current bumper rules, and if there is a flat field. Thanks for all the feedback!
Unread 03-05-2009, 13:46
Lewis, you're too godly at SW. Stop it. You're making me jealous.
Awesome render though, I like the compact layout of the electronics, especially with the cRIO int he back. Looks purdy.
Unread 03-05-2009, 14:28
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
That's definitely one of the nicer Renders I've seen. I really like the drive base too. The only comment I have is that your battery and master breaker placement seem odd. They Seem like they'd be hard to get to if you build an arm or something on top of this chassis.
-Dustin Benedict
Unread 03-05-2009, 14:43
The only thing I can see wrong with such a design is that it seems like it would be difficult to pull the battery out with a manipulator on top of this nice looking chassis. Then again, I'm not much of an engineer. Personally I'd put the battery where the cRIO is.
Unread 03-05-2009, 14:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Is that the Wireless Game Adapter over by the cRIO and right next to that CIM? Based on feedback I have seen from teams I would definitely not put the Game Adapter there. In fact, I don't think I would put it anywhere on the pictured chassis, I would wait until the rest of the robot got designed and try and put it somewhere higher and a little less surrounded by metal and motors.
Unread 03-05-2009, 16:05
Spark The Ancient
hehe, as y'all can tell, I'm not on the electronics team. Agreeably the battery, main breaker, and wireless adapter are in bad places. The manipulator superstructure would provide a good spot of the adapter, and fee up space for the battery and breaker in the back. Perhaps I could design a basic manipulator and work with that. maybe this one
Unread 03-05-2009, 16:33
[Minor details]
From an electronics perspective, I would say that the worst thing about the board isn't the battery placement. The worst thing is the power distribution board placement. The wires poke straight out and will want to travel at least a 1/2" straight out the side of the PDB. In this diagram, it look like the Jaguars in between the CIMs may have some wiring clearance issues unless the electronics team uses 90 degree mounts, so you could push the Jags our a little further so long as they don't interfere with the chain runs. It's great for how compact it is, but it would be a nightmare if a wire ever has to be replaced.
Also, you have a cross beam right underneath the forward-placed CIMs. The 4 Jags in the front MUST have their wiring go underneath that cross beam for the board to be fully removable. The best way to do this is to probably just have the wires poke down underneath the board right out of the PDB, then travel up to the front, then come back up through a hole right next to the Jags. Not hard to do at all, tbh.
[/minor details]
Another option that should give you more room overall is to create 1/16" or 1/8" sheet metal L-brackets for the Jags to stand them up vertically. Your current setup is ideal for this since all of the Jags are paired in their placement, so they could be mounted vertically back-to-back.
I love the weight distribution of this chassis; as-is, it will turn on a dime even at max speed . Great job!
GitHub
pic: Senior Project 1 Alex Cormier Extra Discussion 14 16-08-2010 07:41
saving project as a new project windell747 NI LabVIEW 3 01-02-2009 04:41
pic: Senior Project Mike Nawrot Extra Discussion 11 06-12-2007 22:39
pic: My weekend project mechanicalbrain Extra Discussion 18 04-04-2006 17:12
pic: Senior Project Alex Cormier Robot Showcase 10 10-01-2006 09:50
