Thread Tools |
Rating:
Display Modes |
Re: pic: FRC-34 2009 Swerve Module w/CIM (Front View)
This is an awesome design. I have a question though, I have been designing some of my own crab modules, but a problem I have run into is wiring. How are you going to prevent the wires from getting wrapped around when your modules are turning?
If I remember right from another picture of this module the silver piece on the left side of the bottom circle of the module is used as a a hardware rotation stop. EDIT: Found the post here. The piece is indeed a hardware stop limiting the module to 320 degrees of rotation. Last edited by Vikesrock : 04-05-2009 at 16:51. |
Many teams don't like coaxial swerve because of bevel gears and things, but coax is one way to avoid spinning wires. Last edited by sgreco : 05-05-2009 at 07:10. |
"anything over 360 of motion is overkill"
not at all, you get a much better response time with full rotation, since worst-case for full rotation is 90deg (you can always find the closest goal within a max of 90deg), whereas the worst-case for non-full rotation is twice that. also, with non-full-rotation, think of the situation where you're approaching the limit from one side. as you pass through the limit, the module has to turn 180deg (or however far), which makes for really weird driving. this problem doesn't exist with full rotation for wire wrap, in 07 and 08 (when we did non-coaxial, with cims in the modules), we simply kept track of the number of full rotations, wrote them to the eeprom (persistent across reboots), and had a software limit in the number of rotations. the "unspinning" happened either on button press or automatically during idle time (no joystick inputs). Last edited by tdlrali : 04-05-2009 at 18:00. |
The whole reason I went coaxial was so the programmers couldn't break the drivetrain by spinning too far lol
with coaxial they can send whatever commands they want at it and all that would happen would be a bunch of random spinning at worst |
Oh, those silly programmers...It's always a code problem
But then again, without code, the robot is just a door stop... |
| pic: FRC-34 2009 Swerve Module w/FP (Side View) | Ed Sparks | Extra Discussion | 6 | 09-03-2009 14:02 |
| pic: FRC-34 2009 Frame Concept (Bottom View) | Ed Sparks | Extra Discussion | 1 | 09-03-2009 12:11 |
| pic: FRC-34 2009 Frame Concept (Rear View) | Ed Sparks | Extra Discussion | 2 | 09-03-2009 11:00 |
| pic: FRC 1771 Swerve Module | sdcantrell56 | Extra Discussion | 17 | 13-04-2008 00:36 |
