Go to Post "If a student CAN do it, a student SHOULD do it." - Mr. Lim [more]
Unread 09-05-2009, 19:39
ShaneP's Avatar
ShaneP ShaneP is offline
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Re: pic: Pseudo-Swerve Close Up
Here's a response to a couple questions regarding details asked in this post.
With the current configuration, the drive frame is rotated by a BaneBot 545 motor in a 64:1 planetary gear box which is mounted on the octagon drive frame. A rubber wheel pokes out of the frame and picks up the outer ring of the turntable which is mounted to the external frame of the robot. The octagon drive frame sits on the inner ring of the turntable. You can see the rubber wheel at the back of the robot in this photo: http://www.chiefdelphi.com/media/photos/33368
The setup is a standard 6 wheel drive setup, inside the powered turntable. Both sides are controlled separately. Since the planetary gearbox is not easily back driven, the robot drives like a normal 6 wheel drive when the 545 motor is not powered.
Alternatively, we can take off the rubber wheel and then that "frees" the 6 wheel drive (disconnecting the 545 motor with the external frame), allowing it to rotate within the external frame under it's own turning force. This is how the drive was originally designed, because it allowed the drivers to drive the robot without having to worry about handling the trailer appropriately. If the drivers wished to go straight back, they could do so by simply backing up, and the trailer would move out of the way without any effort. Essentially, you could drive straight through the trailer. However, with this configuration you cannot point the upper portion of the robot. As the robot went through design phases, the requirements for the drive changed. Once we settled on picking up off the ground and having a stationary (relative to the external frame) dumper, we needed to control the external frame, and added the motor which powered the turntable.
Although the 545 motor does create an indirect link between the trailer and drive train (thus restricting turning), this is still overcome by the driver. When the turntable is spun and the drive is rotated at the same speed in the same direction, you get virtually the same "free spin" effect, as you would without the 545 motor attached. This allows you to drive straight through the trailer again.
Throughout our season we were happy and satisfied with how the design performed on the field. Although this drive did make picking up balls off the ground more difficult (especially with the narrow-side pick up), the main benefits allowed us to win some vitally important matches. With its point-and-drive characteristics and traction control, it was a prime robot for playing defence and shutting down a high scoring opponent. Once pushing against an opponents robot, it was nearly impossible for them to get away. We could stick like glue and push them sideways around the field. If they did get away, we could cut them off during their escape (as seen in the video above).
The drive also allowed us to escape when getting pushed, so that we could go and score. We could drive the base in the direction of travel, gain speed and separate from the pushing opponent (or reduce enough force between bumpers so that the friction levels were small enough to become "unstuck"), then change direction to go free. When pinned against a wall, we could angle our driving force in which ever available direction allowed us to break free.
In several cases where the opponents trailer was close by, the base allowed us manoeuvre to it for some last second dumps.
As Eric mentioned, this drive was designed for handling the trailer and low traction surface, so it's not likely to see this drive in use again, at least for this specific purpose.
Overall we were satisfied with the drives performance, and wish we could have made it to Atlanta. We have every intent on making it to IRI, and are greatly looking forward to it.
pic: BeachBot Pseudo-Crab drive, partially assembled Joe Ross Extra Discussion 17 13-03-2009 03:03
Mounting GTS - how close is close? emmell Electrical 7 15-02-2008 00:35
pic: Differential Swerve (Close Up View) with Advanced Gear Kit nonother Extra Discussion 8 16-05-2007 01:14
Pseudo-Code dark.shadow15 Programming 6 11-11-2004 11:07
So close, but not close enough archiver 2001 1 23-06-2002 23:45
