Go to Post This is the best experience you will ever get. - Arefin Bari [more]
Unread 30-05-2009, 11:07
pjco217 pjco217 is offline
FRC #1153
pjco217 is an unknown quantity at this point
pic: Dual CIM Dewalt Transmission
Unread 30-05-2009, 11:08
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Dual CIM Dewalt Transmission
This looks very nice. I particularly like the enclosed gearbox and the lack of standoffs. That should make it much easier to assemble and keep debris out. It would be great to see another render of the inner workings and maybe how you plan to interface the shaft to the dewalt. Also if you dont mind I would love to get the dewalt CAD model.
Mentor 2415
Unread 30-05-2009, 12:04
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
There is one available at...
http://www.chiefdelphi.com/forums/sh...19&postcount=4
Mark
Brick walls are for other people. - Randy Pausch
Unread 30-05-2009, 20:18
ddhotli ddhotli is offline
ddhotli is an unknown quantity at this point
what do you plan to make the sideplates out of?
Unread 31-05-2009, 10:00
FRC #1153
thanks for the comments
I plan on making more renderings to show how the gears and dewalt interface
im still in the designing process right now though.
And i am making the side plates out of 3/8 thick Aluminum and CNC milling them to specs.
Unread 31-05-2009, 10:51
AKA: Sean
What are you planning on doing for the output? Will you be putting a sprocket on the dewalt or having a custom shaft made to direct drive a wheel or something?
Mentor 2415
Unread 31-05-2009, 16:29
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
from a manufacturing standpoint, it might be easier to have to have the sidewalls of the gearbox all one part, so you save all that pocketing/ material removal for one part, and the other side can be a simple flat plate.
Unread 31-05-2009, 18:54
CraigHickman
Unless they're symmetrical, in which case it'd be really fast to crank out a bunch of the same part.
Unread 31-05-2009, 19:21
Spark The Ancient
but they are not, one mounts the CIMs and one mounts the DeWalt
Unread 31-05-2009, 19:35
CraigHickman
And plunging four small holes takes SO much time.
Unread 02-06-2009, 19:57
FRC #1153
For the past two years now we have been direct driving wheels. We modify a Hub and make it so that it is tapped. We then screw that hub onto the output shaft of the dewalt. Then we bolt the hub onto a wheel. We then have a sprocket on the other side of the wheel to chain drive other wheels.
Unread 02-06-2009, 21:17
AKA: Sean
Be careful with direct driving a wheel with 2 cims. The shock loading on the shaft as the wheels change direction can break the shaft so be sure to test this set up before committing your season to it.
Mentor 2415
Unread 03-06-2009, 17:05
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Smile Re: pic: Dual CIM Dewalt Transmission
Good mechanical design principles should always be followed before using software to fix mechanical issues. Having issued that disclaimer, A little software filtering goes a long way to help prevent braking shafts. Have your software folks program your robot with a rate-limiter function on the joystick to PWM output relationship function and broken shafts should become a thing of the past.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
How do you put 2 CIM motors into a Dewalt transmission? jax1488 Technical Discussion 17 26-05-2008 14:04
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
Dual CIM Dewalt??? Joe Johnson Motors 4 30-01-2006 09:49
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
