Re: pic: EWCP Wheel 5"x1"
Suggestion for CNC speed improvement: The inner pockets between the bolt holes could be moved out and included into the profile (making the center hub shaped sort of like a Dog from a shifter) of the Hub, which would cut down on cutting time. It takes more time to pull out of a cut, move over to somewhere, and plunge a new hole then it does to simply keep cutting across with a slightly longer cut line.
Just food for thought. |
| pic: EWCP Founders | Akash Rastogi | Extra Discussion | 5 | 04-26-2009 07:08 PM |
| pic: Pic 2: "caster wheel" crab drive combo | adengler | Extra Discussion | 7 | 01-27-2009 09:14 PM |
| pic: Pic 1: "caster wheel" crab drive combo | adengler | Extra Discussion | 1 | 01-25-2009 05:44 PM |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 01-17-2007 01:21 AM |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 02-18-2005 08:24 PM |
