Go to Post "Only YOU can prevent G22 infractions." - Qbranch [more]
Unread 14-06-2009, 19:18
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is online now
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: pic: Swerve Module Concept (View 1)
What I meant by 3x3 casing is that the housing for the wheel is made from 3"x3" (1/4" W) aluminum extrusion with a piece of 1/4" sheet welded to the top to form a rectangular prism with an open bottom. I placed the sprockets on the outside to both reduce the height and width of the casing in an attempt to save weight. I believe Team 1625 did something similar in 2K8 and I moved the sprocket outside based on advise of one of their members.
The module is steered by a sprocket mounted above the upper bronze bushing. It is not show as it is part of another assembly.
pic: FRC-34 2009 Swerve Module w/CIM (Front View) Ed Sparks Extra Discussion 10 05-05-2009 07:13
pic: FRC-34 2009 Swerve Module w/FP (Side View) Ed Sparks Extra Discussion 6 09-03-2009 14:02
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
