Go to Post Just the fact we were selected to compete in the eliminations energized the kids more than anything I had seen - Taylor [more]
Unread 14-06-2009, 20:22
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: pic: Swerve Module Concept (View 1)
You might consider putting a ring near the bottom of the module which would effectively reduce the lever arm from 3+ inches to under 1/2 inch.
Assuming that a robot can push with 180 LBS force (150 LBS * 1.2 CoF) and that your wheel will not move (is sideways against a lip) ... probably as close to worst case scenario as we need to get ... in your current design you'd see ~ 630 INLB force on the mounting, and if you were to put a ring near the bottom you'd see ~90INLB.
BTW, I'm not picking on the design ... I really like it. I'm just concerned that it will fail at the mount to the frame. ***Gut feeling***
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
pic: FRC-34 2009 Swerve Module w/CIM (Front View) Ed Sparks Extra Discussion 10 05-05-2009 07:13
pic: FRC-34 2009 Swerve Module w/FP (Side View) Ed Sparks Extra Discussion 6 09-03-2009 14:02
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
