Go to Post Yup, looks like FIRST is infiltrating the American sports culture. And that's the long and the short of it. - Taylor [more]
Unread 16-06-2009, 22:05
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: pic: Swerve Module Concept (View 1)
Originally Posted by Dave McLaughlin View Post
Daniel,
I appreciate the concern and the suggestions. I completely understand that you're not picking on my poor little module I have considered adding a ring like you suggested. Possibly out of delrin or something of the like. It seems like there is a definite divide on Delphi between the 111 style and the 118 style module.
From what I have seen on Delphi and in person, there are numerous swerves without support rings that have worked just fine. I'm planning on CADing up a version with the ring to see how I would have to alter the frame and module to make it work, but I find that I am of the persuasion that prefers the no-ring approach. I would like to here more about the pros and cons off adding a ring if you would humor me with the discussion...
Both designs have tradeoffs and their use truely depends on design intent.
Since I'm of the pro ring design, I'll put forth what I see as it's biggest pros and cons:
Pro: Less stress on the whole module -- with the ring low (near the ground) you have a significantly shorter lever arm and therefore much lower stress (see above post). This will allow you to make your side plates thinner (and lighter) while increasing their robustness.
Con: More framework. The frame must contact the module at 2 rings that are not close to each other. That means more framework and possibly a heavier chassis.
Ring designs tend to have less ground clearance as well, but with the side gear that low in your design I don't see that as much of an issue.
If anyone else would like to chime in, I'd like to hear y'alls opinion as well.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
pic: FRC-34 2009 Swerve Module w/CIM (Front View) Ed Sparks Extra Discussion 10 05-05-2009 07:13
pic: FRC-34 2009 Swerve Module w/FP (Side View) Ed Sparks Extra Discussion 6 09-03-2009 14:02
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
