Thread Tools |
Rating:
Display Modes |
#17
Re: pic: cRIO CAN Jag
Yes, that would be good....
The thing about connectors is: Good connectors have both a positive mechanical connection for the housing (the housing halves cannot be pulled apart without first releasing something), and a positive pressure contact connection (the pin is encased in the socket). The PWM cables lack the housing lock, and the RJ series has only a single side contact. |
| Failed attempt to explain JAG linearity | vamfun | Technical Discussion | 66 | 05-06-2009 13:13 |
| 2009 Camera and Jag inventor models problem | Creator Mat | CAD | 5 | 08-03-2009 14:05 |
| 1 Jag and 1 Victor not responding correctly. | elbuo | NI LabVIEW | 4 | 17-02-2009 22:57 |
| How can you add more rom space to the cRIO? | Comatose | FRC Control System | 8 | 05-02-2009 21:16 |
