Thread Tools |
Rating:
Display Modes |
#20
Re: pic: cRIO CAN Jag
Thanks for the explanation, Don!
I guess I wasn't quite clear expressing what my concern was, and as usual got the terminology wrong because I'm not an expert on the subject. What I meant was that the wiring method had a bunch of RJ connectors in series. The signal has to go thru all the connectors in the chain before it gets to the end. If any fail, the signal won't get through to those past it. Is my understanding correct? |
| Failed attempt to explain JAG linearity | vamfun | Technical Discussion | 66 | 05-06-2009 13:13 |
| 2009 Camera and Jag inventor models problem | Creator Mat | CAD | 5 | 08-03-2009 14:05 |
| 1 Jag and 1 Victor not responding correctly. | elbuo | NI LabVIEW | 4 | 17-02-2009 22:57 |
| How can you add more rom space to the cRIO? | Comatose | FRC Control System | 8 | 05-02-2009 21:16 |
