Thread Tools |
Rating:
Display Modes |
#21
Re: pic: cRIO CAN Jag
Considering that in most cases you'll be plugging in your CAN bus only once when you wire your robot, I don't see a concern with the RJ series connectors. Your land line telephones are also connected with RJ series connectors and they also take a fair amount of abuse, their connections have a fairly low failure rate in that environment as well as in network systems.
As a model railroader, we use a similar connection for our data bus standards for digital command control with very few problems. It should work well. All I can say to FIRST is... "When CAN we play?" ![]() |
| Failed attempt to explain JAG linearity | vamfun | Technical Discussion | 66 | 05-06-2009 13:13 |
| 2009 Camera and Jag inventor models problem | Creator Mat | CAD | 5 | 08-03-2009 14:05 |
| 1 Jag and 1 Victor not responding correctly. | elbuo | NI LabVIEW | 4 | 17-02-2009 22:57 |
| How can you add more rom space to the cRIO? | Comatose | FRC Control System | 8 | 05-02-2009 21:16 |
