Go to Post Ahem, a climbing xerox machine. Also known as the scariest type of xerox machine this Earth has ever seen. - itsjustjon [more]
Unread 20-06-2009, 20:35
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: pic: cRIO CAN Jag
As an additional point of interest:
Keep in mind that your program will need to send the data to a specific address on the CAN bus, so that means that each of your speed controllers will need a unique number... can you guess where this is going?
If you need to replace a speed controller on your can bus, you will need to do one of 2 things, either program your new speed controller with the old ones address, or determine the address of the new one (its not imprinted on it anywhere) and change your code.
Its one of those rock and a hard place problems.
Also, as a network engineer, and working in IT for 8 years now, if you use high quality connectors, and don't abuse them you shouldn't need to worry about those connectors. I have actually seen the cable come apart before the connector came out of the jack in the wall!
However If you buy your cables at the dollar / 50 cent / dumpster store good luck to you!
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
