Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 28-06-2009, 18:31
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: cRIO CAN Jag
NItro had the same three motor controllers on it last year at NIWeek (first week of Aug 2008). Only back then, the plastics weren't on it. The CAN control was functional back then.
A couple of other clarifications.
1. The left-most CAN jack of the bottom Jaguar is indeed for termination. A 120 ohm resistor is crimped across the inner two contacts.
2. The CAN jack is nor RJ45, it is a 6 position 4 conductor jack (6P4C).
3. When replacing a Jaguar, an address does need to be assigned to it. This is a trivial process and can be done in seconds.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
