Go to Post You know you've overdosed on FIRST when you set your alarm clock to your team # ex: 9:32 - bladetech932 [more]
Unread 04-07-2009, 10:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: cRIO CAN Jag
Originally Posted by biojae View Post
i just noticed in the picture that there is a split cord at the base of the cRio, one side goes to the jags and the other goes to an enclosure, is that another termination resistor?
Good eye. The NI catalog describes an accessory for the cRIO CAN module that is exactly that, a cable assembly which includes a termination resistor.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
