Go to Post I thought you guys were surposed to be nerds. - Funzo [more]
Unread 05-07-2009, 02:04
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: cRIO CAN Jag
Originally Posted by biojae View Post
i just noticed in the picture that there is a split cord at the base of the cRio, one side goes to the jags and the other goes to an enclosure, is that another termination resistor?
Yes, but that shouldn't be surprising. The CAN bus uses 2 termination resistors, ideally located at each end. Both termination resistors are 120 ohm. Neither the Jaguar nor NI-9853 (*) provide internal termination since they make no assumptions regarding the bus topology nor where they are placed.
(*) This module was used by NI on NItro.. but I would not make any assumptions about this. NItro is a technology demonstration vehicle.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
