Go to Post Another human taking a job that a robot could do... - Ryan Simpson [more]
  #32   Spotlight this post!
Unread 05-07-2009, 02:18
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: cRIO CAN Jag
Originally Posted by biojae View Post
It looks like it could be made easily, how much does NI sell it for? (We will probably get one in the kit though)
Also what module # is in the cRIO?
I know that the jags can do 1mb per second comms, and there is a 1mb module but there is the possibility of us having the slower comms, (Though i don't believe that we will ever need to have that much data throughput)
The cable pictured is not available from NI. It was a small custom build for NItro. It is a small piece of 9 conductor ribbon cable with 4 flat ribbon DB-9 connectors crimped on it. One DB-9 is used for connecting to the Jaguars, one for connecting a termination resistor, one to connect to the NI CAN module, and the final for connecting a CAN bus analyzer. The parts are cheap and no soldering required.
A comment on the bus bandwidth.. the number of packets per second you can get on CAN depends on a number of factors. If you consider a 29-bit message identifier (as used by Jaguar) and average bit stuffing, on a 1 Mb/s network, you can get >12,800 1-byte packets per second and >9,300 4-byte packets per second. I bet that some crazy team will be complaining in a year or so about the need for more CAN bandwidth . The nice thing about CAN is that there are no collisions, so you know when it is busy the data still gets through.
Last edited by s1900ahon : 05-07-2009 at 16:11. Reason: Can't add. Forgot the DB-9 facing the module.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
