Re: pic: Team 79 Summer Project Electronics Board
Just a tip from me if you put the wires through the board like that make holes much larger than the connector on the wire, i've had a board like this on our 08 bot and it was really annoying to replase wires and connectors
thank! thats a VERY VERY good tip. We had that problem in 2007 with our bot. But luckily we didn't have to replace a lot of things. We just had to remove excessive victors and spikes, so removing those wires were a bit annoying.
where is your controller going to go?
Bryan,
I would recommend a loop in each wire so that you have the ability to remove the connectors to replace defective components. Nice render! |
Well, believe it or not... all of those components on that board, the breaker panel, AND the controller ALL fit on that board. I hated that because of all the errors we encountered. So i spaced everything out. I'm aiming to place the controller in a protected environment on the top of the robot's compressor plates that way i can see what its up to, program and access if necessary, and it'll be safe and covered by lexan. |
Bryan,
Don't forget that the compressor gets hot if it running often. It is best to keep components away from the heat. |
| pic: Team 79's Summer Project | ATannahill | Extra Discussion | 12 | 03-11-2009 09:38 |
| pic: Team 578 electronics board | commodoredl | Extra Discussion | 3 | 02-02-2009 21:02 |
| pic: Team 1676's Electronics Board | Graham Donaldson | Extra Discussion | 9 | 20-02-2007 10:18 |
| pic: Team 1701 Electronics Board | imax48236 | Extra Discussion | 10 | 29-01-2007 20:18 |
| pic: TEAM 1636 Electronics Board | LightWaves1636 | Extra Discussion | 1 | 14-02-2006 19:08 |
