Go to Post - oh dear - Will it be January soon? - JaneYoung [more]
Unread 05-07-2009, 22:45
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Re: pic: Team 79 Summer Project Electronics Board
thank! thats a VERY VERY good tip. We had that problem in 2007 with our bot. But luckily we didn't have to replace a lot of things. We just had to remove excessive victors and spikes, so removing those wires were a bit annoying.
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 06-07-2009, 01:07
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
where is your controller going to go?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 06-07-2009, 09:16
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Bryan,
I would recommend a loop in each wire so that you have the ability to remove the connectors to replace defective components. Nice render!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-07-2009, 01:22
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
Originally Posted by Al Skierkiewicz View Post
Bryan,
Jeez! everytime i check CD theres always some good advice for free. I can't believe we didn't think of that! That totally makes sense because the components ARE pretty old, so we might have to replace them sometime.
Well, believe it or not... all of those components on that board, the breaker panel, AND the controller ALL fit on that board. I hated that because of all the errors we encountered. So i spaced everything out. I'm aiming to place the controller in a protected environment on the top of the robot's compressor plates that way i can see what its up to, program and access if necessary, and it'll be safe and covered by lexan.
Unread 07-07-2009, 07:19
Bryan,
Don't forget that the compressor gets hot if it running often. It is best to keep components away from the heat.
Al
WB9UVJ
www.wildstang.org
pic: Team 79's Summer Project ATannahill Extra Discussion 12 03-11-2009 09:38
pic: Team 578 electronics board commodoredl Extra Discussion 3 02-02-2009 21:02
pic: Team 1676's Electronics Board Graham Donaldson Extra Discussion 9 20-02-2007 10:18
pic: Team 1701 Electronics Board imax48236 Extra Discussion 10 29-01-2007 20:18
pic: TEAM 1636 Electronics Board LightWaves1636 Extra Discussion 1 14-02-2006 19:08
