Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 13-07-2009, 18:43
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Rock Box Chassis
Nice! What's it take to change out that center wheel?
Unread 13-07-2009, 20:44
ajlapp ajlapp is offline
AKA: Anthony Lapp
Do you have a flat, or other type of indexing thing to keep the two eccentrics aligned with each other?
The bolt it self has a flat milled down it's length. Each cam has a "d" hole.
Each wheel can be removed through the pocket. the openings are larger on the bottom to facilitate sprockets or other drive components. The center shaft is held in place with snap rings. Once the outside ring is removed the wheel is free to lift out....provided you've removed the chains.
There is no doubt this is a challenging chassis to assemble initially, but I'm hoping to be able to offer it much cheaper than the Universal Chassis. It has many of the same features and is "rock solid" once it is assembled.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 13-07-2009, 21:37
Great product! One that won't unleash a fury of posts as to whether or not it is legal as well . How heavy is it?
Unread 13-07-2009, 21:50
Better not have the same stupid discussion again. Its been beaten to death.
Another great product, Anthony.
Yay for time savings. And I'd also like an estimate on price as well as weight.
Unread 14-07-2009, 08:28
AKA: Anthony Lapp
As pictured, with chains, 7.4 lbs. This particular rail is 27" long. A 37" version will also be available.
Price is not yet set.
Anthony Lapp
RobotOpen
Unread 14-07-2009, 08:29
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Tony,
Do you have any holes drilled for bumper mounting? Perhaps slots to set the bumper into and then a firm attachment on the bottom. You know someone is going to do it. What is the travel on the tensioning adjustments? I take it the front and back wheels are slightly higher than the center? Are you bringing one to IRI?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-07-2009, 08:36
AKA: Anthony Lapp
As of now there are no extra features incorporated. I am investigating bumper mounts, toughbox mounts and solutions for the Andymark suite of shifters.
Total travel at each wheel is 1".
There is a non-adjustable .125" rocker built into the chassis.
I will have this with me at IRI along with the Wild Swerve modules and the Universal Chassis, both long and short.
Anthony Lapp
RobotOpen
pic: Rock n' Roll Robots fbaldi25 Extra Discussion 8 11-10-2008 10:57
pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. bubbablahmon Extra Discussion 15 22-01-2008 09:40
pic: rock climber 1902_Battery_SGT FIRST Tech Challenge 11 02-06-2006 06:48
pic: Robots Rock! John Wanninger Extra Discussion 2 22-10-2005 10:52
pic: Hard Rock Cafe CD47-Bot Extra Discussion 2 16-04-2003 16:44
