Re: pic: Wild Swerve Module, Near Production
The drive shaft is .5" hex to interface with Andymark gearsets. The weight, as pictured is 8.4 lbs. |
can it be modified to allow a wider wheel?
That is some really awesome stuff to hear. Can we choose anodizing colors?
Got to see this unit in person at IRI and I was very impressed with it.
Ditto. It was pretty hefty but seemed really solidly built. I might try and convince my team to buy one before we build our Poly Swerve, but I doubt we have the offseason build funding.
I'm still telling you man, that poly swerve doesn't sound like too good of an idea. The strain on the walls of the module might be too much. CAD it out and try some stress testing first.
A quick thanks to everyone who stopped by our booth this weekend at IRI to chat!
Overall the response to the Wild Swerve modules was very positive. I'm excited to bring this very famous design to the FIRST world. Please stay tuned to our website for production dates and pricing. |
#10
what are the gears used in this? and what is the final reduction also? thanks
#12
Anthony can give the details, but the gears are standard AndyMark. There are multiple combinations that can be used to give several different final drive ratios.
#13
All ratios start with a 14 tooth CIM gear to a 35 tooth .375" hex gear. The remaining gears can be any that follow the Toughbox spread of 64 teeth max. There are many ratios possible, the four most relevant using the CIM are as follows: 14.8:1 or about 4.8 ft/sec at max power 9.87:1 or about 7.2 ft/sec at max power 6.94:1 or about 10.36 ft/sec at max power 5.36:1 or about 13.4 ft/sec at max power |
#14
It was a bit heavy but it also used standard AM gears without lightening. A little work on those by a team would go a long way.
| pic: Team 221 LLC. - Wild Swerve Module | ajlapp | Extra Discussion | 77 | 06-11-2009 17:33 |
| pic: Swerve Module Concept (View 2) | Dave McLaughlin | Extra Discussion | 5 | 17-06-2009 00:15 |
| pic: stangs swerve module | Aren_Hill | Extra Discussion | 8 | 23-04-2007 08:15 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
