Go to Post I...want...to...go...to...Champs. REALLY REALLY BADLY. - CalTran [more]
Unread 18-07-2009, 22:44
EricH EricH is offline
Re: pic: T Shirt Shooting Robot
Originally Posted by gallo26 View Post
I'm also confused about that... What do you mean exactly? Because if the air is released, shouldn't the pressure on the surfaces inside the reservoir be just a few psi (or whatever is left over. usually 0-5psi)? And how is it instantly filling up in the gun is firing? that's an instant release... I think I'm confused here
It's physics and such. Let's use some everyday examples...
You always have 14 psi pressing down on you, due to atmospheric pressure. But now, you decide to have some fun. You go into a room that is totally sealed, with an air compressor hose coming down to a smaller chamber that seals to your skin. You have gauges and things of that nature all over the room. The room gauges read zero to start--they've been calibrated so 14 psi is zero. You pressurize the smaller chamber to some higher pressure (say, 50 psi as the gauges measure). Now, something jerks the small chamber away from your skin. Instantly, all the pressure is released from that chamber into the other chamber, and air being air, it fills the entire space as fast as it can. The gauges now measure more air pressure than zero (how much more depends on the size of the room and the size of the small chamber). Instantly.
But you've rigged this room with a small air cannon, and it's a small room, with an insane amount of pressure in the small chamber. Suddenly, the small chamber breaks, and all that air finds the cannon, which is loaded. The ammo moves under the pressure, which at the instant the chamber broke, was applied throughout the room, and shoots out, releasing all the pressure. The room returns to the normal air pressure of 14 psi, the gauges read zero, and you now have to reload and try again.
Does this help?
Unread 18-07-2009, 22:49
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Yes sir! I wasn't sure what part he was talking about, tank or barrel. Thank You
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Robot T-shirt Ideas lynca General Forum 5 10-07-2009 09:14
pic: Team Fusion's T-Shirt Shooting Robot jdhawg Robot Showcase 72 23-05-2009 23:39
1390's Robot T-shirt Shooter JonathanTillett Robot Showcase 10 29-07-2007 20:16
New Robot shirt at Hot Topic Elgin Clock Chit-Chat 10 09-10-2004 03:13
