Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
Unread 25-07-2009, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: 3/4" Plywood Frame
There are many grades of plywood; you want aircraft plywood if possible. It uses many layers of light wood.
regular plywood, like used for house construction, uses only a few layers, and is not as strong (or light) as aircraft plywood. Marine plywood uses a few more layers, but isn't as light. You might consider making your own plywood, two 1/4" aircraft ply outer layers with foam and 1/4" spacers in-between - lighter and just as strong.
For stiffness, use pieces mounted 90 degrees to the plane - glue and screw.
It would be heavier than aluminum, but plenty strong. Use some aluminum U channel along the outer edge to give very good impact strength.
But nice concept!
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
pic: plywood+mill = wooden omniwheels?!? Stuart Extra Discussion 4 06-02-2007 14:35
grip on dusty plywood greencactus3 Technical Discussion 5 12-01-2005 18:41
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
