Go to Post I can't claim to be an expert in the stess analysis field - I just play one on TV, er CD, er - okay, so call me a poser! - petek [more]
Unread 25-07-2009, 22:20
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: pic: 3/4" Plywood Frame
We have made several plywood frames over the years. If you use 3/8" plywood (I would use Baltic Birch which has at least 5 layers and no voids) as a top with a 1/4" Baltic Birch Ply bottom - sandwiching 1/2" -3/4" X 3/4" spacers around the perimeter, all glued and clamped, with solid blocks at mounting points for pillow blocks and super-structures you will create a hollow chassis which is light and incredibly strong and stiff. For inspiration look to light wieght, wooden boat construction. Go for it and good luck.
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
pic: plywood+mill = wooden omniwheels?!? Stuart Extra Discussion 4 06-02-2007 14:35
grip on dusty plywood greencactus3 Technical Discussion 5 12-01-2005 18:41
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
