Go to Post While Grace will carry you through good times and victory, Professionalism will carry you through hard times and defeat. - Venkatesh [more]
Unread 02-08-2009, 20:20
Re: pic: Wild Swerve Module, Near Production
I'm still telling you man, that poly swerve doesn't sound like too good of an idea. The strain on the walls of the module might be too much. CAD it out and try some stress testing first.
It's being done 100% in CAD first, yeah. This is the OTHER reason I wanna borrow 221's model
Unread 03-08-2009, 22:18
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
what are the gears used in this? and what is the final reduction also? thanks
Unread 03-08-2009, 22:38
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Anthony can give the details, but the gears are standard AndyMark. There are multiple combinations that can be used to give several different final drive ratios.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 03-08-2009, 23:45
ajlapp ajlapp is offline
AKA: Anthony Lapp
The gears used are standard Andymark.
All ratios start with a 14 tooth CIM gear to a 35 tooth .375" hex gear.
The remaining gears can be any that follow the Toughbox spread of 64 teeth max.
There are many ratios possible, the four most relevant using the CIM are as follows:
14.8:1 or about 4.8 ft/sec at max power
9.87:1 or about 7.2 ft/sec at max power
6.94:1 or about 10.36 ft/sec at max power
5.36:1 or about 13.4 ft/sec at max power
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
