Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 03-08-2009, 00:25
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 1323 Thinks Pink Part 2
Originally Posted by NickE View Post
Looks good. (Its amazing how much room is left over with all of those Jaguars.)
Where are your relays and pneumatic components going? How is the battery restrained? How thick is the tubing on the frame rails?
The gearboxes look similar to our 2008 gearboxes. Are you using plastic sideplates? Is the rear wheel direct driven?
One thing you might consider to stiffen the chassis is to have the wooden baseplate extend under the siderails (except where the wheels are.)
Thanks Nick,
I'm probably going to wire it all up and then release an updated pic. The pneumatics will go in the front, since there is a lot of room there. I'll probably have to reorganize the electronics to fit everything.
The back wheel is directly driven and I think I might use pocketed aluminum sideplates. I noticed with some of our gearboxes that were made with delrin flex a lot more than I would've liked. But for lunacy they were fine.
As for the idea of extending the wood, that is a great idea. I will end up redoing the wood then. Thanks,
-RC
R.C.
MadTown Robotics Team 1323
pic: 1323 Thinks Pink R.C. Extra Discussion 17 25-07-2009 01:20
pic: THINK PINK 233 Roccobot 2k9's Pink Gabe Salas Jr. Extra Discussion 4 11-03-2009 19:31
pic: 1323 R.C. Extra Discussion 3 07-02-2009 23:24
pic: 1323 Robot comwiz7 Robot Showcase 21 17-03-2008 15:30
pic: 1323 electrical Robo_Coyote Extra Discussion 1 20-01-2007 19:32
