Go to Post Yes, blame Gary. For everything. - MissInformation [more]
Unread 09-08-2009, 16:42
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
pic: Touchscreen interface, theory of operation
original thread that lead to this http://www.chiefdelphi.com/forums/sh...ad.php?t=77903
Last edited by biojae : 09-08-2009 at 17:34. Reason: added link to original thread
Unread 09-08-2009, 16:47
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Touchscreen interface, theory of operation
This looks like a great and interesting idea, however I would urge caution about designing to the 2009 Driver Station interface specifically. Given some of its problems this year, and Bill Miller's statement that a Classmates PC would be in next years' kit, there may be different if not easier ways to interface in the future.
Unread 09-08-2009, 17:11
Would you be able to use the touch screen to map a waypoint based autonomous mode on the fly? Because there were multiple times where I would have loved that (mostly while "breaking" air lock loading auto modes from the likes of 1114).
Unread 09-08-2009, 17:31
biojae's Avatar
yes, that is the point of the screen
The blog says that the laptop is to be used with the driver station. and there should always be analog inputs on the driverstation. if the laptop is to be used as the DS, then drivers may be able to be installed, but i think it may just be for a dashboard
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 09-08-2009, 18:53
biojae's Avatar
but, the points have to be entered before the robot is enabled, so a limit of 50 points is imposed. 50 because the driverstation updates at 50hz and it would only take 1 sec. best case.
The points are sent in order received on the screen,
and if they aren’t inputted fast enough the last points may not be received.
so a memory will be implemented on the screen (as it has its own processor),
and on the next power up, act like the points were inputted from a person, but much faster
Unread 09-08-2009, 18:58
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Why not just resend the points every second? The point number input would always tell which point is being sent so why not 1, 2, 3, ..., 49, 50, 1, 2, ... ?
--Ryan
FRC 766, 2015-, Mentor
Unread 09-08-2009, 19:06
biojae's Avatar
--Ryan
I hadn't thought of that.
that would allow for error correction, and last second point changes
thats a good idea
Unread 09-08-2009, 19:26
This discussion brings up an interesting rules question.
Presently, you can download code to a robot when it is on the field by plugging your laptop into the other Ethernet port. Doing a soft reboot would then complete the update. A few times this year we have done so to get in "last minute" code changes without having to tether up the bot in the queuing line.
However, if properly written, one could eliminate the need to reboot the robot altogether. Here's what I'm thinking:
1. Create your autonomous mode on the laptop.
2. The software then creates a text file representing the sequence of autonomous commands.
3. The laptop is connected to the driver station Ethernet port.
4. Using FTP, the text file is placed on the cRIO.
5. Upon the initialization of autonomous mode, the software parses the text file and acts upon the stored sequence of commands.
As long as all of these steps are complete by the time the robot is enabled, is there anything in 2009 (or past) rules that would preclude this scheme? As far as I am concerned, this solution is far easier than using an Arduino board and writing a custom communications protocol.
I think I have some coding to do.
(Even if the 2010 rules explicitly disallow transmission of packets from a laptop to the cRIO at any point when the robot is on the field, such a scheme would probably still be the easiest way to tweak autonomous modes without ever needing to rebuild or even reboot)
Unread 09-08-2009, 20:06
Billfred's Avatar
Billfred Billfred is offline
I can't think of any 2009 rules that prohibits FTPing a file of commands over pre-match. 195 used a similar strategy in 2006 to let them create waypoints to make them more effective in defending against opponents in autonomous (theirs, as I remember, used a PDA connected to the serial port to dump the data before the match).
I'll ask a silly question: What if you want to run your manipulator (including specifying a particular position) during your autonomous routine?
Unread 09-08-2009, 20:59
biojae's Avatar
this is a general implemetation, based off of our 2009 lunacy robot. there are no manipulators that need to be run in auto. if our 2010 robot has a manipulator then the code will have to adapt.
the screen can display anything that we want it to, so we could have it display various options on the screen.
Unread 10-08-2009, 00:32
biojae's Avatar
yes, but our drivers didn't want a laptop up at the Driver station stand, they wanted some thing small, that could update the auto mode on the fly without dealing with uploading things to the robot.
the touch screen is only about 2.7'' by 2.1''
for comparison our laptop is 24" by 18"
Unread 10-08-2009, 12:26
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Wasn't the concept of this introduced in Atlanta during the Championship Event on the big screen in 2008 when the cRIO was first officially & publicly announced?
What ever happened to that?
As a person with a CAD background, it seemed really cool to just draw a path & have a robot follow that.
Never saw anyone use anything like that this year though.
So disappointing.
Hopefully in the future more people will attempt this & succeed.
Unread 10-08-2009, 19:54
biojae's Avatar
So disappointing.
I dont know, i never saw that video, or pictures of it.
that is basically what i am trying to accomplish, my team at the LA regional didnt like how the robot kept crashing into the driver station wall, and they wanted to have something to be able to change the behavior of the bot without having to tweak values in the code (no text file for us ).
one of them remembered the screen at atlanta, and wanted it put on the robot for last second strategy changes.
(we used binary switches but they couldnt ever remember what each switch did, or if it even worked)
Unread 14-08-2009, 00:47
biojae's Avatar
This is similar to what it is going to look like
Unread 14-08-2009, 00:48
Did you model this yourself or did you find it somewhere?
pic: Operation Jellybean Mr MOE Extra Discussion 4 02-05-2007 23:08
pic: 967 hanging operation CD47-Bot Extra Discussion 2 16-03-2004 12:37
pic: 781 - All Operation Robot CD47-Bot Robot Showcase 9 02-03-2004 23:55
my theory on IA robot180 Website Design/Showcase 7 21-10-2003 18:05
