Go to Post "Check out those sexy transmissions!" - Eric W. Jones [more]
Unread 10-08-2009, 17:14
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: 6WD base
Unless you are a pro, assume that the material just outside of the aluminum gets annealed during the welding process. i.e. if you are making a chassis our of 6061 T6 AL, assume strength as annealed 6061. We have had several weld fractures, but they were due to 1 of three issues:
1. Pushing the envelope (we have built a lot of stuff using welded 0.030" AL)
2. Poor joint design (we had 1 failure where afterwards we realised it was a poorly designed joint)
3. Poor welds quality. We have had a weld failure where the weld quality was just plain poor. High inclusion due to carelessness. This didn't make it onto a competition bot.
pic: Prototype 6WD kajeevan Extra Discussion 26 06-07-2009 03:18
pic: Cheap 6WD s_forbes Extra Discussion 50 27-12-2008 21:14
pic: re-modified 6wd spc295 Extra Discussion 15 19-11-2008 15:14
