Go to Post Learn to respect the opinions of others, even if they are the complete opposite of yours. - Hallry [more]
Unread 10-08-2009, 19:03
Re: pic: 6WD base
This isn't specific to this base, but more of a general statement on welded joints.
You can save your team a lot of heartache if you spend some time thinking about and analyzing the forces that are acting on the welded joints. If you can then design the joints so that weld alone doesn't take the stress from these forces, you'll end up with a much more reliable design obviously.
You're rear cross member is a decent example of this, the way it currently is an impact on it's rear will cause it to push directly onto the siderails. If the siderails extended past the cross member, and the cross member was between them, the weld would take the entire load. A lot of the times it's really a trivial difference.
I'd also advise you spend a little time learning about the different types/shapes of welded joints. Once again, a usually trivial change in frame design can result in a joint that is much stronger due to the weld itself being easier to do, or a stronger weld.
pic: Prototype 6WD kajeevan Extra Discussion 26 06-07-2009 03:18
pic: Cheap 6WD s_forbes Extra Discussion 50 27-12-2008 21:14
pic: re-modified 6wd spc295 Extra Discussion 15 19-11-2008 15:14
