Go to Post what hint? - Electricia 1599 [more]
Unread 11-08-2009, 17:56
Brenton Brenton is offline
FRC #0060
Brenton will become famous soon enough
pic: Team 60 Prototype Wheels
Unread 11-08-2009, 17:57
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: pic: Team 60 Prototype Wheels
Those wheels look awesome!! great job!
My question would be, how is that mill working for you? is it worth the money or should we wait and look into a more expensive mill?
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 11-08-2009, 18:16
FRC #0060
Larger Mill!!!!! The extra money will go a long way. Look for one with an R8 spindle. The heavier the better. The micro-mill uses an mt2 taper which is hard to find tooling for and tends to cost more; forget finding anything other than collets. I've spent more money on tooling and vises than I did on the mill. The spindle is also underpowered limiting cuts to .030" at 15fpm to avoid stalling. It also requires constant maintenance or it starts to fall apart fast. We use a full size bridgeport and a much larger harbor freight mill in the shop.
Hope this helps.
Former Team 60 President
Team 60,1633 Mentor
Unread 11-08-2009, 18:37
McGurky's Avatar
Geek
AKA: Kyle McGurk
Great thanks Brenton, If you were to do it all over again what mill would you buy?
Unread 11-08-2009, 18:49
FRC #0060
If you're looking for a mill to convert to cnc I'd go with harbor freight's small mill. It weighs over three times as much and cncfusion sells a conversion kit that includes ball screws. I will warn you that making your own cnc will require a huge chunk of time, and learning how to use it effectively will require even more. If you're looking for a manual mill I'd ask some of the machinists that float around these forums. They know much more than I do (I have a degree in textile design, robots are just a hobby).
Team 60,1633 Mentor
Unread 11-08-2009, 19:24
Nice wheels and nicely photographed. I too have a CNCed HF Micro Mill and while small, it's still quite useful. The extended Y axis kit is a must, and the long table kit is nice too. Understanding its limitations, it is a decent machine if you have no other.
Unread 11-08-2009, 19:48
FRC #0060
I totally agree, for the price it can't be beat. I've also fitted my mill with th
e extended x and y axis kits. A spray mist coolant system is also a great purchase, they can be found for around $30 but do require a small compressor. It totally eliminates welding chips to your endmill and makes a huge difference in the finish without the mess of a flood coolant system. It also helps your endmills last longer.
Team 60,1633 Mentor
Unread 11-08-2009, 19:55
Happy Birthday! Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Just a quick question, where can you get cheap misters, I've looking for one but haven't found a cheap one. At the shop its all flood, but on the one of the manual mills I wanted to add a mister.
Thanks.
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 11-08-2009, 20:04
Billfred's Avatar
Billfred Billfred is offline
A question from looking at the picture: Do the two sides just clamp down on the tube, or does the tube interlock some way I'm not seeing?
Unread 11-08-2009, 20:13
FRC #0060
Thanks.
Enco Spra-Kool Midget Model #505-2124, $39 right now but it goes on sale often. It hooks to a bolt. I have mine attached to a magnet for easy moving. It's easy to use, the one problem I have with it is you twist the nozzle to adjust the flow, making it dangerous to adjust while the machine is running.
Team 60,1633 Mentor
Unread 11-08-2009, 20:20
FRC #0060
The tube and tread are clamped by the side plates. The fit is tight, neither move at all.
Team 60,1633 Mentor
Unread 11-08-2009, 20:22
OUTWORK US
Thanks so much. That helps a lot
Gary Chahal
Unread 12-08-2009, 13:43
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Do you just glue the treads on???
2009 Palmetto Regional Champs
Unread 12-08-2009, 13:47
I bet they do the same thing that they and 254 have been doing for years, judging by the picture. It looks like they clamp the tread on by using the lip milled into the rim and tightening the two sides together and then pop rivet the ends down.
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
Some may argue that these wheels require a lot of work to manufacture. When you look at it from that perspective, you aren't gaining a whole lot over something like an AM Plaction wheel in terms of cost and weight.
Simply put though, I'm inspired by this. I love the sprocket design. The wheels look fantastic and the design looks rugged. Great job. Nice photography as well.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: Team 100 Prototype Base =Martin=Taylor= Extra Discussion 8 21-12-2007 01:06
pic: Team 100 Prototype Base =Martin=Taylor= Extra Discussion 11 10-10-2007 07:39
pic: BCR294 Prototype wheels AdamHeard Extra Discussion 6 07-09-2007 13:51
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
