Go to Post I fear sometimes as time increases between the present and when someone started, some sight of just how hard it can be to field a functioning robot for a young team is lost. - xForceDee [more]
Unread 14-08-2009, 17:15
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
Re: pic: FP Gearbox (KOP Gears - 2)
I can't tell from the photo, did you remember to make slots or holes for the air to circulate through the motor? I also can't tell if the pinion is making full engagement with the gear. It looks like the engagement is at the very end of the pinion. A thinner side plate (or a recess in the current one) will move that closer to the motor's bearing and make life easier on the motor shaft.
I'm guessing the use of the hex bearings eliminated the need for any lathe work. That's a nice option for teams without access to a lathe.
How are you locating the hex shaft axially?
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
pic: FP Gearbox (KOP Gears) R.C. Extra Discussion 2 14-08-2009 00:43
KOP transmission 2006- Pitch of Gears neoshaakti Motors 1 05-02-2008 00:06
KOP gearbox? Andy Brockway Kit & Additional Hardware 52 06-01-2007 18:56
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
