Go to Post [I]'Twas the night before ship day, And all through the shop, Not a creature was stirring, Not even[/I] -- Naah, they'll never believe that. - GaryVoshol [more]
Unread 14-08-2009, 18:47
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: FP Gearbox (KOP Gears - 2)
Originally Posted by Brandon Holley View Post
We eventually added a 2nd gear parallel to the gear the motor pinion is touching to keep the 2 FP motors from stripping gear teeth off of that gear. We turned the extra hub off of one to fit it in there, it ended up being the difference maker and kept the gearbox running all year w/o any problems.
Brandon, That is a great idea. I think we will end up doing the same.
Originally Posted by squirrel View Post
neat! I'm curious why you used hex bore bearings, just turn the ends of the shafts round instead....that's how we made our single stage FP gearbox and it worked fine. easy to make, we had the bearings laying around already
Funny thing, our whole bot used hex bearings and I think we had over 100 bearings laying around along with over a bajillion bushings. So we have the option of .5 bore, .375 bore, .375 hex bore. So I figured I could be lazy and just use .375 hex all the way.
Originally Posted by Ivan Helmrich View Post
I can't tell from the photo, did you remember to make slots or holes for the air to circulate through the motor? I also can't tell if the pinion is making full engagement with the gear. It looks like the engagement is at the very end of the pinion. A thinner side plate (or a recess in the current one) will move that closer to the motor's bearing and make life easier on the motor shaft.
I'm guessing the use of the hex bearings eliminated the need for any lathe work. That's a nice option for teams without access to a lathe.
How are you locating the hex shaft axially?
This was before we added the holes for the air, I relized from another CAD drawing I had that I didn't add the holes for circulation. The pinion fully engages when you tighten the gearbox.
Thanks for the help,
-RC
R.C.
MadTown Robotics Team 1323
pic: FP Gearbox (KOP Gears) R.C. Extra Discussion 2 14-08-2009 00:43
KOP transmission 2006- Pitch of Gears neoshaakti Motors 1 05-02-2008 00:06
KOP gearbox? Andy Brockway Kit & Additional Hardware 52 06-01-2007 18:56
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
