Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 17-08-2009, 21:27
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Re: pic: Blizzard proto base
The wheels are 24mm wide. Baltic birch plywood only comes in metric so we take 2 sheets of 12mm spread wood glue on them and sandwich together under a couple of batteries. Then drill a hole and turn them round on a lath. Really easy and is usually done by second day of build.
pic: Blizzard X - Week 4 Mr. Lim Extra Discussion 9 30-01-2009 14:36
PIC: 1902 Exploding Bacon proto type base Doug Leppard Robot Showcase 11 24-01-2009 12:17
pic: Madtown 1323 Proto 2 R.C. Extra Discussion 12 20-06-2008 20:27
pic: Blizzard VIII Steve W Robot Showcase 28 25-02-2007 00:50
pic: Blizzard Steve W Robot Showcase 22 08-03-2006 08:32
