Go to Post If my shop was snowed in and my unfinished robot was sitting in there, I'd dig it out with a plastic spoon or melt it out with a Bic lighter if I had to. Every hour counts. If there's a will, there's a way to make it happen. - sanddrag [more]
Unread 22-08-2009, 13:16
EricH EricH is offline
Re: pic: Front left view of ai cannon
I understand that the tank is metal; we used to get a similarly sized black one in the KOP. Pneumatics weren't exactly common while we had that... Something about no onboard compressor and the tank weighed about 12-13 lbs on a 130 lb robot (and the cylinder rules didn't help).
I'm not sure that parallel batteries are the best thing, especially if you charge them in parallel. (There was a discussion on this earlier this summer, IIRC.) Being a mechanical, I defer to the electrical guys on that, though.
I wasn't referring to the tether cable when I mentioned spaghetti. Matter of fact, I couldn't tell there was a tether cable on there... this may be due to about 20-30 wires going all over the place.
Unread 22-08-2009, 17:23
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
oh, sorry. the wires are actually tied down, it's just that there are so many of them in such a small area. anyway, thanks, and if you would like a schematic, i may be able to do something like that.
Unread 23-08-2009, 12:18
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
wow! That looks pretty cool! I'd love to see a video of this in action.
It looks to me like the "Spaghetti" of wires is just long PWM cables that were bundled together. add a few bundles... But otherwise it looks like all your wires are nicely tied down.
How far does it shoot an object? What object does it shoot?
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 23-08-2009, 12:22
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
I looked at it, and it doesn't look like it would be charged in parallel. Each battery has its own connector to allow for a single battery charging. The first battery just runs to the second battery, which then runs to the power switch. Correct me if I'm wrong, but that's just what I noticed. But you are correct in saying it's not the best thing to charge them in parallel.
Unread 23-08-2009, 20:05
FRC #1236
it can shoot T-shirts about 150' when it's at 120 PSI, but water bottles about 200'+. it's especially fun to watch at night when there is a GlowStick in the water filled bottle. it can shoot anything that can fit in the barrel without too much force.
and i do usually charge them in parallel it just takes longer, a lot longer, but i still get the same battery power when they're done charging. the reason i don't charge them seperatly is because i only have one charger and a lot of school. and to answer your last question about a video or more it has been raining, A LOT, but i do plan on putting it on youtube sometime. i'll tell you all the link and when i have posted each.
Unread 23-08-2009, 20:23
You may find this thread interesting reading: http://www.chiefdelphi.com/forums/sh...ad.php?t=77837
Admittedly, they were planning to run 6 batteries in parallel, but you should still pay attention, because quite a bit of what they said will apply to your case.
Unread 24-08-2009, 01:11
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
Yeah your right. Its just like having a larger battery. But Of course with that you should always watch out and make sure that its fully charged. I remember hearing that if one cell of the battery is not fully charged (since it charges in cells, and they talked about this in that thread) that the output of all the other cells will decrease. And if you were to have a dead cell, charging would definitely be a problem. But i suppose those are all issues to attack when they happen (mainly the dead cell thing)
But I would love to see a video of that thing. It looks awesome. I know from our cannons we shoot t shirts, but we put a soda can in front of it and it just flew! Quite a site to see.
Please keep us updated on any revisions and any new videos you take after it stops raining
Unread 24-08-2009, 08:29
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
That looks really good! could use a little organization, but overall its pretty awesome! as far as the batteries go, on our teams t-shirt launcher we are working on, we have one battery for the electronics and one battery for all of the motors and compressors. This way when the motor battery goes dead we can swap it out without turning off all of the lights/sounds and electronics. We are also planning to have enough battery boxes on the robot for close to 4-5 batteries, this will allow us to quickly swap the connection if the battery goes dead.
Hopefully this will help you in your further designing of this robot!!
-McGurky
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 25-08-2009, 22:53
FRC #1236
Here is the link to the video you all wanted to see of the air cannon. ENJOY!
http://www.youtube.com/watch?v=KIRuK9-lKII
pic: 2008 Dynamos - Front View SSMike Robot Showcase 4 25-02-2008 17:31
pic: 379 Front View Teaser Kyle379 Extra Discussion 2 14-02-2008 08:02
pic: front view Tim566 Extra Discussion 2 24-03-2006 23:03
pic: MegaMaid front View yodameister Robot Showcase 13 11-02-2006 19:11
pic: ROBOT FRONT VIEW CD47-Bot Robot Showcase 4 25-02-2003 13:34
