Go to Post P.S. No matter what happens a build season, you will always have memories. - Briansmithtown [more]
Unread 22-08-2009, 23:29
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
pic: 2079 Six Wheel Skid
Unread 22-08-2009, 23:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: pic: 2079 Six Wheel Skid
Looks nice.
Just one question. Have you thought of putting any cross brackets for lateral support? Besides that, it looks beaut.
1058 PVC Pirates 2016 - xxxx
Unread 23-08-2009, 01:58
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Originally Posted by BrendanB View Post
Looks nice.
He might be using the belly pan as a cross brace, but it probably would not hurt to run a cross brace in the center. Also you could design that to work as a more secure battery mount.
Looks completely sweet, I love the lightening pattern and the chain tensioning wheel brackets.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 23-08-2009, 11:01
I'm curious as to what made you decide on a tensioned bracket with which you have to move the whole wheel as apposed to regular chain tensioned with an adjustable HDPE/UHMW/Delrin standoff. Looks great though Steven, reminds me a little of the 1503 frame Nick Lawrence showed me.
Unread 23-08-2009, 12:28
sgreco's Avatar
AKA: Steven Greco
FRC #2079
That was the intention, but you guys are right, I should add some cross supports in there. I want them to go all the way through to the outer part of the part of the frame for structural reasons, I think I cut out too much material.
The reason I tensioned the chain as shown is because I wanted to put some sort of cross support inside the wheel alley, that goes the entire length of the bot, and it doesn't leave to much room for a tensioner. I think it might be worth it to keep all the cut outs I have and reinfoce it from within, just so it'll still look cool. I will have to look into that though.
Unread 23-08-2009, 13:31
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
If you wanted to avoid running tube cross supports, you could use a piece of 3/8" baltic birch plywood to run the entire underside of the chassis. It would be very light and stiff, not to mention how easy it is to mount things to wood. It also insulates your electrical components as a nice side effect.
Mentor 2415
Unread 23-08-2009, 16:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I would re-evaluate your wheel design. a pound is extremely heavy for a 4" wheel. The average 4" wheel is generally somewhere around 0.5 lb or less.
2001-2004: Team 100
2006-Present: Team 254
pic: ALARM (2079) 2009 Wheel Module tubeheaD37 Extra Discussion 1 25-02-2009 07:20
pic: six wheel drive articulated stair climber Bertman Extra Discussion 14 01-12-2008 00:47
Best Form Of Six Wheel Drive? thefro526 Technical Discussion 54 28-03-2007 01:18
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Skid marks T967 General Forum 10 31-01-2003 07:24
