Go to Post Building a drone during Ri3D is going to be a challenge... - Ginger Power [more]
Unread 23-08-2009, 13:51
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: pic: Chassis Idea
Another electrical suggestion. Don't mount your gaming adapter down low in the frame especially that close to your high current victors and CIMs. You want the radio higher in the robot and away from sources of interference for optimal data transmission and minimal data loss.
I also agree that unless you have a very complicated robot, you'll likely only need one digital sidecar.
On wire size, the lower the AWG (American Wire Gauge) number, the larger the wire, more current carrying capacity, and lower resistance per foot resulting in lower voltage drop. Therfore, #6 is supplied in the KOP for your main power circuits, but you could use #4 and it would be legal. In cases where #16 is recommended you could use #14, 12, or 10 if you felt that voltage drop would be a significant issue and it would be legal. Just remember, larger wire is more weight, so unless you know you have a voltage drop issue, it's probably unnecessary.
Voltage drop is also directly related to efficiency. Voltage drop and wire resistance is Watts of wasted energy in heat. This can have a serious impact on battery performance when dealing with mechanisms which run at full power for long periods of time during a match. Vacuum venturis, high speed shooters and collector mechanisms are certainly worth watching for energy losses.
Keep thinking up new designs you're on the right track.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
pic: Chassis Base Shira Extra Discussion 9 01-02-2009 14:10
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
