Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 24-08-2009, 08:03
JesseK JesseK is online now
Re: pic: Swerve Drive Can SolidWorks Concept (cheap version)
It would be more taxing on the team, but based on what I've heard I would recommend tapping the ends of the live axles and putting a bolt in them rather than using a c-clip.
Also, to prevent racking you could make this out of 3" box extrusion and make it a little longer at the bottom. That way you could have at least 1/4" wide strips running between the sides at the bottom. The aluminum already turns in at the bottom, so making it longer and cutting a hole (rather than a whole slot) for the wheel would easily allow you to do this.
GitHub
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
pic: Unique drive concept Joe G. Extra Discussion 36 12-05-2007 20:27
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
