Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Unread 24-08-2009, 07:53
Bootsie's Avatar
Bootsie Bootsie is offline
Ex-Captain and Mentor
FRC #0955 (Raiderbot)
Bootsie is on a distinguished road
pic: Four-Speed Ball-Lock Single-Pneumatic Transmission Design
Unread 24-08-2009, 07:56
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Four-Speed Ball-Lock Single-Pneumatic Transmission Design
Here is a very cool demo of a ball lock transmission for FIRST from team 222:
http://www.youtube.com/watch?v=D7ng4OWilUY
One question: Are you concerned about the precise positioning of the pneumatic cylinder? I know that in my tests with a double solenoid and magnetic reed switch, I had some issues with repeatability.
Unread 24-08-2009, 10:08
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Yes, we are concerned and we are currently working out a test bed to determine if the precision required is possible. Our proof of concept (actuating the solenoids manually) proved we could get multiple positions but was not nearly as precise as we need. The next step is to use software to do a timed set of actuations.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 24-08-2009, 10:43
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Looks good! I'm going to reiterate Jared's caution about using a double solenoid setup. The first ball lock we built in 2004 was a three speed. We experimented with using a double solenoid setup but there was no real repeatability. What we ended up doing instead was using two cylinders for the three selections. We joined our transmissions together through shifting forks and a linkage. One cylinder would shift to first and third gear while the second cylinder acted as a wedge to shift into second gear while we vented the cylinder for shifting between first and third gear. The setup worked well for us, but was alot of weight and alot of work for a third gear that saw very little action. Not to discourage this design in any way, but there are very very few games where you would need more than 2 speeds.
Also another tip on the plunger shaft, using the pneumatics as a spring doesn't always work. Your best bet if you plan on making a solid plunger shaft would be to get it heat treated. We always run a spring loaded plunger shaft. This year we had a slight alignment issue in one gearbox where the balls were getting jammed and even though we had springs the springs were fully compressed and the cylinder acting as the spring at this point nearly destroyed our plunger shaft.
Anyway take your time on the ball lock shifter and enjoy it. They hold up and function very well. We've been running ball lock shifters since 2004. Each year they keep getting smaller and simpler. Best of luck!
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 24-08-2009, 17:22
Fe_Will's Avatar
AKA: Will
We spent about a month working around different solutions the the problem of moving the plunger shaft into more than two shift positions. Personally I would prefer a lead screw but we got to the point that having the screw being .25" in diameter and then having the plunger/spring assembly on the end we weren't confident it would be possible. Like you said, if something were to bounce around in there chances were it would snap off the plunger.
I know it was discussed in team 222'5 2004 thread but, if anyone has ideas for shifting a ball lock in 3 or more positions it would be greatly appreciated.
Unread 24-08-2009, 17:33
EricH EricH is online now
Would a servo (or a gang of servos) work, with a decently long lever arm? You'd have to work out the linkage to operate it, but I think you could do it. Many moons ago, my dad and I discussed a ball-lock with servos to shift, but were not having an easy time figuring out how exactly to do it.
Unread 24-08-2009, 17:45
Fe_Will's Avatar
AKA: Will
I'm not sure the amount of force required to make a shift. Our main concern is that the servos can be painfully slow. Adding a lever arm could potentially increase the time it takes. I hadn't thought of ganging servos before... that is an interesting thought.
Unread 24-08-2009, 18:21
How about multiple cylinders?
If you get a 2" stroke piston and attach a 1" stroke piston to the end of that, you can achieve 0", 1", 2", or 3" of length by firing them in sequence.
Bimba also sells multi-position cylinders that essentially accomplish the same thing in a more compact package. We used one on our Lunacy bot - you can custom order a wide variety of StrokeA/StrokeB combinations that are then controlled by a pair of solenoids.
Unread 24-08-2009, 18:27
Fe_Will's Avatar
AKA: Will
I didn't realize those are legal... we'll look into it, thanks.
Unread 24-08-2009, 18:29
Bootsie's Avatar
I am curious as to the details of your pneumatic setup, especially programming-wise. Were you using sensors, like MRS's or some such? Or were you timing the shifts?
Also, how were the shifts not predictable/repeatable? We have only experienced "coasting" so far, where the piston keeps moving a bit after solenoids close, as the tubes are filling with air. Did you have any different problems?
Thanks a bunch!
Unread 25-08-2009, 13:07
AKA: Cliff Mock
Rookie Year: 1997
Our shifts were not reliable because of the coasting you mentioned. We actually didn't even get to the stage of running the cylinders in the transmission because of the coast It is very difficult to get exactly the same amount of pressure at both ports of the cylinder. We didn't spend alot of time once we couldn't really get rid of the drift.
Servos would definitely work, but they would be slow to shift. Our transmissions take very little pressure to shift. They will also stay engaged for quite a while without any pressure at all.
You could still use a lead screw setup, but use a linkage to connect it to a spring loaded plunger shaft.
I'm sure there are many other ways to shift this, but I'm drawing a blank right now. It's too bad multi-position cylinders aren't FIRST legal.
Unread 25-08-2009, 13:20
Bootsie's Avatar
Why the adherence to the spring-loaded plunger ideal? Do you guys shift at full pressure? I had the idea to pick a spring strength, then set your pressure to provide that spring strength and nix the spring altogether. Have you guys ever tried this low-pressure shifting without a spring?
Unread 25-08-2009, 14:20
In 2009 they were legal. We used one to control the deflector angle on our shooter.
<R71> part D states:
In addition to the pneumatic cylinders provided in the Kit Of Parts and the “free” pneumatic cylinders available for order through the Free Pneumatic Components Order Form, additional air cylinders or rotary actuators may be used. Cylinders may be of any configuration, and may be of any size up to a maximum of 24-inch stroke and 2-inch diameter.
Unread 25-08-2009, 14:27
AKA: Cliff Mock
Rookie Year: 1997
We have shifted at low pressure however the problem comes if things get out of alignment a solid plunger shaft pneumatics are going to keep pressing at a constant PSI trying to make this plunger push the balls out to engage the gear. Well the balls will eventually wear the portion of the plunger shaft that pushes the balls out. This is where our use of a spring loader plunger comes into play.
While we are still applying pressure trying to shift, the "floating" spring loaded portion of our plunger shaft is rotating on the plunger shaft and not wearing as bad. Also if the solid plunger is held rigid and not allowed to rotate you will see increased wear either on the plunger shaft or the balls themselves. Spring loaded or not is something we've tossed back and forth many times ourselves, but keep going back to spring loaded because it works and I've heard of others having issues with solid plunger shafts that are not heat treated. I will say though we tend to over design things, but we'd rather be overbuilt than underbuilt.
Unread 25-08-2009, 14:55
Bootsie's Avatar
That is very useful advice, thank you!
White Paper Discuss: Team 33 Four Speed Transmission CD47-Bot Extra Discussion 10 19-04-2013 14:22
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 30-12-2006 16:39
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
