Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 27-08-2009, 12:35
Rion Atkinson's Avatar
The CAD Guy
Re: pic: 6WD Chassis
Originally Posted by Jared341 View Post
2) You could probably eliminate some of those vertical supports and still have sufficient frame rigidity.
3) 59 lbs sounds a little heavy for what is pictured (are you including the battery in this weight?). What kind of material, e.g. wall thickness, is your structural tubing?
Thanks for the supports advice. I will definitely pull some out.
Ya.. i was thinking it was a little heavy... Yes the battery is included. The wood board... Inventor thinks that is Aluminum 6061, I can't find a wood option and it was originally going to be that.
The frame is made of 1" extruded aluminum(sides are 1/8").
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 14:20
