Originally Posted by Formerly Famous
The only problem is wood is not an option to choose from.. And I don't if you can manually change the density in Inventor...
You can. I forget how, but you can. And if wood isn't an option, then I just lost respect for Inventor. You go into the properties, and pick your type of wood--pine or oak should do the trick. (It doesn't have "wood" as an option because every wood is a different type of wood, and has a different density.)
