Go to Post And another big factor in winning. Luck. - Carol [more]
Unread 31-08-2009, 15:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: pic: Revolution Co-Axial Swerve Module - Team 221 LLC.
What supports the side loads on the horizontal shaft caused by the bevel gear?
You normally don't want to side-load axial bearings, so I've been scared of using e-clips on the ends of the shaft and having them pushing against the inner race of the axial bearings at each end.
Unread 31-08-2009, 15:28
ajlapp ajlapp is offline
AKA: Anthony Lapp
The frc118 plan calls for thin walled bushings that hold the miter gear in location and push the thrust loads against the inner race of the bearing.
The prototype pictured has snap rings holding the miter gear in place. The same will be true for the drive sprocket, though they are currently not in place.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Cyber Blue and Team 221 LLC "Wild Swerve" Chris Fultz General Forum 27 08-02-2010 14:47
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
Team 221 LLC. Partnership Opportunity ajlapp General Forum 0 08-01-2009 08:30
Team 221 LLC. Universal Chassis In Stock ajlapp General Forum 23 02-01-2009 09:07
